Wiped on update
emmsee
Wiped on update
Post by emmsee »
I recently updated Qbittorent to 4.3.5 and when I rebooted and restarted all finalised downloads and current downloads have been wiped - all information gone!
How do I fix this?
regards
Mike
screenshot of Qbittorent.png (22.83 KiB) Viewed 1160 times
laz305
Re: Wiped on update
Post by laz305 »
This is why I never update. Never goes smoothly
unseen19
Re: Wiped on update
Post by unseen19 »
no reference to your original version but this could maybe help (fastresume file extension) viewtopic.php?f=14&t=8603
Trackfinder
Re: Wiped on update
Post by Trackfinder »
To avoid this accident, once a week I make a backup of the qBittorent backup folder (Computer/Users/User/AppData/Local/BT_Backup)
If anything like this happen, I just substitute that folder.
I never had this problem, but whenever I formatted my computer, I just copied this folder into the newly installed qBittorent backup folder and everything is OK.
DeathStalker
Re: Wiped on update
Post by DeathStalker »
I guess I'll wait for the next version to be more thoroughly tested.
--- DS
