encrypt function
encrypt function
Hello! Please add encrypt traffic function, like utorrent. Its help bypass provider restrictions.
Re: encrypt function
I have this on my copy of version 4.3.4.1
- Selection_013.jpg (64.24 KiB) Viewed 2746 times
Yeah, it already has encryption. By default, its "prefer", meaning it will connect encrypted IF possible, and connect without IF the other peer does not support encryption.
Oh really, thanks. But its dont work for me, speed 60KB/sec. When i use vpn all fine.
Oh, this encryption is not like that. VPN encryption is all traffic encrypted, hidden*. But this encryption is weak. It can only counter the most basic traffic shaping solutions. So it's not very effective at all to tell the truth.
https://en.wikipedia.org/wiki/BitTorren ... encryption
* Some VPN providers not only give you the option to use multiple protocols (ie.: OpenVPN, IKEv2, Wireguard), multiple ports BUT they sometimes also let you use "Stealth" protocols that will look like normal HTTPS traffic all the time. But these capabilities vary by VPN provider. Some give more, some give less.
