Hi. since updating my I cant use magnet links in drag and drop. I just get a X
I can do it manually but drag and dropping was awesome. I tried removing associations restarting and reneabling . but hasn't worked .
Has anything changed? did you remove this feature for security?
Not sure if its a bug or not. But thought I should lt you know
thanks for a great product.
KKBB
updated to latest qbittorent build and its broken Magnet links
Re: updated to latest qbittorent build and its broken Magnet links
Is this 4.3.6?
I've been holding off on upgrading till I see some comments and reports on it.
Wish this board was more active
--- DS
--- DS
was a bug created in the correct section for follow up/confirmation?
viewtopic.php?f=14&t=3505
