Unathorized
Unathorized
When I try to access the WebUI I am met with "unauthorized". I tried accessing from an incognito tab and it worked. What is the problem? Is there a way to fix it without disabling CSRFprotection?
Re: Unathorized
Did you ever figure this out? I'm having the same problem.
Re: Unathorized
Could you guys link which docker image you are using?
(because there is no official)
