qbit shutdown randomly
billyofthebob
Post by billyofthebob »
Been happening for about a month. Was running several versions, but on the latest now 4.3.8. No trace of anything, but does seem to happen overnight. I'll go to bed and it will be shut down the next morning?
I tried finding the logs under user/app data but the last log files in there are from July 2020.
Any known issue and/or can someone point me to where the logs might be to maybe get a sense of what is happening?
billyofthebob
Re: qbit shutdown randomly
Running last version of Windows 10 with all updates applied.
unseen19
Post by unseen19 »
Dodging the obvious first: is anything configured in QBT>Tools>on download done?
If not, what tells you the windows event viewer>application? Have you checked the AV logs ?
