Hi. Dont know how to solve this of if its possible. Everytime something downloads macos opens that folder where the download direction is, find that annoying to have all thes folders open up all the time something starts to download. Anyone knows how to fix this would be appreciatet.
Thanks
Folder opens after download
Re: Folder opens after download
Do you have the option enabled: Options -> Downloads -> [x] Run external program on torrent completion
Try disabling it.
Try disabling it.
Thanks for the tip but I don’t have that option checked. I’ve had in the past but not anymore.
