Unexpected network error
BlazingChaos
Post by BlazingChaos »
I don't know what this means but I have tried everything to get them working. I get this usually after a week but when it happens to one it happens to all of them. I have tried changing the port, have changed the version of the client, have tried messing with router settings, I have done force starting what people suggested and it works for like an hour and stops. i have been dealing with for a while and really could use help
error qbitt.PNG (16.37 KiB) Viewed 1153 times
unseen19
Re: Unexpected network error
Post by unseen19 »
wired network?
directly to your ISP router, wired, makes a difference?
Computer up to date and any AV software or similar running?
BlazingChaos
it is a wired connection
no antivirus software and it I up to date
