https://github.com/C0nw0nk/qBittorrent
qBittorrent
qBittorrent Windows Automatic batch file command line script with many features
Script Features
Automatically delete completed torrents older than X number of days
Automatically delete torrents with no seeders
Automatically delete torrents that have never been seen completed
Automatically pause completed torrents to save bandwidth to stop seeding them
Automatically force start downloading torrents that have not completely downloaded
Automatically Fix for qBittorrent for torrents stuck infinitely at 99.X% when a torrent hits greater than >99% and it has infinite time remaining we need to force rechecking of the torrent to fix it
Automatically check torrents for blacklisted file types inside them and tell qBittorrent to not download these file types
blacklisted_filetypes=".exe .txt .text .nfo .jpg .bmp .ico .png .gif .torrent .url .lnk .link .diz .ini .xml .sql .cmd .bat .dll .py .vbs .reg .html .htm .db .thumb .readme Sample sample. padding_file"
Add your own to the list like powershell scripts etc that are junk files you do not want sneaking in inside of the torrents
https://github.com/C0nw0nk/qBittorrent/ ... md#L38-L40
Setup / Usage
qBittorrent WebUI Login is all you need to turn on / enable in your qBittorrent settings in order to use this script
Settings
https://github.com/C0nw0nk/qBittorrent/ ... bt.cmd#L10
To run this Automatically open command prompt and RUN COMMAND PROMPT AS ADMINISTRATOR and use the following command : SCHTASKS /CREATE /SC HOURLY /TN "Cons qBittorrent Script" /RU "SYSTEM" /TR "C:\Windows\System32\cmd.exe /c start /B "C:\qbt\qbt.cmd"
Any questions or contributions please feel free to make a pull request on github lets improve upon this
