Hello,
I'm setting up a home server with Windows on(needed for certain programs I use).
qBittorrent will be running on the server when that's done.
What is the easiest way to start magnet links on a remote PC?
I would be sad if I had to remote into it every time.
BTW. This is what I found myself:
https://github.com/bogenpirat/remote-torrent-adder
I just don't know if it's a good solution.
Magnet links started remotely
Re: Magnet links started remotely
I use that extension. It works well.
