show downloads or torrents in a chronological order
I have been using qbitorrent for a short time (couple of months) . Hope someone can help me in a simple question. I would like to know how I can put the downloads (or torrents) in chronological order when they were downloaded, ie the newest ones below (like I used to do with utorrent 2.2.1) - a date column, for instance? Is it possible? Thanks in advance!
Re: show downloads or torrents in a chronological order
Add the column "Added ON" and you will get the date you added the torrent to QBT
Worked perfectly! Thank you very much!
