Network interface limited to NordVPN, extreme slowdown
wengang1
Post by wengang1 »
Hi all.
I have a computer that is connected to Comcast, use NordVPN with QBT. I can confirm speed test is about 60 Mbps with NordVPN running.
A while back, I changed the network interface in QBT to just the interface that exists when NordVPN is connected. This ensures that nothing downloads at any time except through the VPN. I set this up on another computer that has a different ISP and it worked fine, but on the Comcast computer, this change appears to slow downloading to near zero, often just a few KBps.
I would switch it back to Any Interface, but I know the way it is set up now is the only way to be truly anonymous in QBT.
What can I try here? I know the connection is fast because I see the 60 Mbps even as QBT is barely downloading.
Thanks.
Gary
