How can I restore paused torrents in the list ?
The paused torrents disappered in version 4.1.3, but the list counted number is ok .
Dissapered paused torrents in the list
Re: Dissapered paused torrents in the list
When you select all torrents on the left side panel at the main screen do you see them after that?
I doesnt see in all torrent the paused ones .
Maybe I switched on a filter when the progran gui halted , I clicked on somewhere .
I using old version because 4.3.8 and 4.3.8. gui halted after using some days .
After restart program cannot load gui after hours .
Then intall other versions , but the problem is parmanently .
About 10-15 times program started ( in all version ) the gui cannot load . After installed an other version gui can load only 10-15 times started the program .
