Torrent GUI information not showing
pirateroberts
Post by pirateroberts »
Hi all,
I was running the gcr.io/linuxserver/qbittorrent image qBittorrent version 4.3.5 in docker on an Ubuntu host for quite some time. Then I got the idea I should update to the newest image to get a newer and updated qBittorrent version 4.4.0. Unfortunately that version was banned at my main torrent site so I shut down the container and restarted the old container with version 4.3.5 hoping the settings hadn't changed. (stupidly enough I forgot to snapshot the settings folder).
On the positive side everything seems to work, I can seed torrents, I can download new torrents, only problem is the torrent information tabs are all blank. So I guess the version 4.4.0 changed the settings file/db in some way so that the 4.3.5 version can't access that particular information anymore.
Anyone has any ideas what's going on and if there's an easy fix available?
br,
Roberts
pirateroberts
Re: Torrent GUI information not showing
Must have been some sort of weird browser bug. When I opened developer tools and reloaded the page it fixed itself and now it works. Very interesting. :)
