Rookie mess up...
Using the UnRAID docker... I was initially in the webGUI and was setting up but then I put my WAN IP in the Gui address and I can't get back into the Gui.
Editing the docker just gives me port info. I tried entering IP as well (192.168.1.102:8080 but it didn't work either.
Tried deleting/reinstalling... Nope
Router port forwards are in place...
Can't access Gui using WAN:Port either
Anyone have a suggestion?
Accidently changed webgui to WAN... can't change back
Re: Accidently changed webgui to WAN... can't change back
Is there a way to delete the container/setup files? I deleted the docker and redownloaded it and it ran with the same old configuration as the last install.
Thanks Hammer...sledgehammer_999 wrote: ↑Wed Feb 16, 2022 1:11 am https://github.com/qbittorrent/qBittorr ... s_settings
I was also thinking about deleting the container since with appdata cleanup plugin
