phpBB FUBARness
phpBB FUBARness
Basically the mail problem is still there.
If I set it to smtp , you'll get mails for password reset BUT no topic notifications.
If I set it to php mail() , you'll receive topic notifications, BUT the password reset breaks.
So .. what should I do? Honestly I would simply change down the engine but will have to look up how can I migrate everything if that's possible.
Or Chris... Is it possible to use Drupal as a main site + use the forums ? (Or maybe I should install a drupal here and remove everything except the forum module.. not sure which would be better.)
Re: phpBB FUBARness
Honestly.. I have no idea. The mail works perfectly. I get the password recovery , the topic notification. If you encounter ANY problem, please message me ASAP!
Re: phpBB FUBARness
Well.. spammers again. ATLBL, 3D captcha, manual confirmation ... there is no way stopping them.
