Kill Switch Using NordVpn
jpborn
Post by jpborn »
Hey all,
I'm really having problem with the kill switch in qtorrent, using on a Macbook pro latest os, all up to date...
I can't seem to figure out how to set it and everytime my computer goes to sleep and nordvpn kicks off, qtorrent keeps going and I'm having all kinds of issues...
I guess a. how to set so qtorrent goes off automatically when the vpn drops, best if it just quits.
The nordvpn side is a no go, the version I can use doesn't have an auto kill switch, to kill an app, that would be the best but it has to come from qtorrent side...
Thanks in advance...
DigitalSin69
Re: Kill Switch Using NordVpn
Post by DigitalSin69 »
funny thing; I use the a different VPN and had the same issue. Computer sleeps and the VPN shuts down but does not kill internet traffic. qBitt continues, without VPN in place.
After numerous emails to VPN support, no fix.
My Solution? Don't let the computer sleep. If you cannot raise the bridge, lower the water.
