hi,
i'm using qBittorrent 4.3.9 with Xubuntu 20.04
when i try to search something, in the lowest part of the frame appears a warning message: "Si è verificato un errore di ricerca" ("search error") and no torrent link appears.
research scripts are all updated so the problem should be a program's bug
what can i do to solve it, please?
thx
Error in searching
Re: Error in searching
hello,
I have Xubuntu 20.04.4 LTS, Kernel 5.13.0-37-generic
I got the same error message while searching.
I had installed Qbittorrent under Snap.
I uninstalled the application under Snap and reinstalled under synaptic (V4.3.9) and everything works again!
Good Luck.
Good Luck.
