Since re-installing qbt on a new PC I've been plagued by this message.
In my settings I have Torrent Management mode set to Auto and the 3 folders I have specified are all there and the settings are correct.
All the specified folders are on drive F:\bt downloads, F:\bt active torrents, F:\bt finished torrents
When I receive this error message I right click on the torrent and select Torrent Options
The window I then see - attached - shows Automatic Torrent Management unchecked and Save At shows as J:\bt downloads. If I then check the Auto Management box the Save At location changes to the correct drive, F:, and on resume all is well.
What I don't understand is where the reference to J: is coming from and, more importantly how can I permanently change it?
Errored: The System cannot find the path specified
- Screenshot 2022-05-16 094643.png (22.47 KiB) Viewed 2289 times
- Newbie
Re: Errored: The System cannot find the path specified
Recently, I've also been plagued by this message.
It just happened when I updated to v4.6.6.
