Dark Skins for QBittorrent
billyjc
Post by billyjc »
legibledark and dracula2
Some dark qBittorrent skins available on the net are hard to read because they have dark text on a dark background and not enough contrast. In some, the progress percentage number doesn't fully display with most resolution settings.
So, I made these two dark skins with more contrast. legibledark is mostly white on a very dark blue background and dracula2 is mostly white on a very dark gray background. They're both very easy to read and their progress percentage number fully displays perfectly with any resolution setting.
legibledark.rar
(245.89 KiB) Downloaded 31880 times
To install a skin, go to Tools > Options > Behavior. Under Interface put a checkmark on "Use custom UI Theme." Underneath that, go to the right of "UI Theme file:" and click on the little yellow folder. Browse to the theme file and then click on "Apply" and "OK". Completely restart qBittorrent (exit out of the tray notification icon) and the theme will display. (see image below)
S.H.Bouwhuis
Re: Legible Dark Skin for QBittorrent
Post by S.H.Bouwhuis »
1. Does this theme also work for v4.3.9?
2. How do I install a theme?
3. HUGE thanks for creating a dark theme!
billyjc
Re: Dark Skins for QBittorrent
Post by billyjc »
@S.H.Bouwhuis
The themes should work on all versions. You're welcome.
Thanks, I will sticky this for others that look for a dark theme.
billyjc
Post by billyjc »
You're very welcome Nemo.
billyjc
dracula2 Skin
Post by billyjc »
dracula2 skin is mostly white on a very dark gray background and the progress percentage number also fully displays perfectly with any resolution setting.
dracula2.rar
(245.18 KiB) Downloaded 27386 times
billyjc
Please Delete this Entry
Post by billyjc »
S.H.Bouwhuis
There is a bug in the LegibleDark theme. You can't see whether checkboxes are ticked or not. For instance, in the window which opens when you load a torrent or magnet where you can choose which files to download you cannot see what the state is of the checkboxes.
billyjc
Post by billyjc »
Sounds as if something corrupted. Please delete the old file, download it again and then install it again. That will fix it.
S.H.Bouwhuis
Yes, now it does work. Thanks for the fix.
jfjfjf
Post by jfjfjf »
Prima! Thanks a lot!
jmcc84
Post by jmcc84 »
All those dark skins are awful. The devs should consider adding an official dark mode to QBitTorrrent.
footloose
Post by footloose »
BIG THANK YOU
These skins are great!
The devs should make one of them the official dark skin mode!
fuorigioco1981
Post by fuorigioco1981 »
excellent skins thanks!
billyjc
Post by billyjc »
You're very welcome.
