No access to some places (partitions)
alejoplin1
Post by alejoplin1 »
Hello
It is when I want to use the feature "Move the download folder" or something like that , no it is here, I translate "Backup path" or Download path" ?
Then the box gives only 2 choices : / and /home
So for this I kept Deluge instead, for the moment
Re: No access to some places (partitions)
This is only a permission issue. Make sure your folders have proper permissions and you are running qBittorrent with the right user.
IF you are using Docker or something, permissions get way more complicated. You have to define the folders in the Docker file. Without that, qBittorrent simply does not get any access to them.
