Download qBittorrent ver. 2.9.7-1 from Ubuntu software center in Ubuntu 12.04 LTS.
Click qBittorrent in Unity the hard disk led flashes on-off a small window opens with icon and in a flash goes off but nothing else, I cant find the application.
How can I fix this.
qBittorrent does not open
Re: qBittorrent does not open
I have a similar problem. QBittorrent has been running perfectly for a considerable time - also on Ubuntu 12.04.
It will now no longer open though locked to Launcher, icon doesn't 'flash' when clicked.Attempts via Dash results in same situation.
Tried reinstalling, terminal output is:-
ray@ray-Aspire-5735:~$ sudo apt-get install qbittorrent
[sudo] password for ray:
Reading package lists... Done
Building dependency tree
Reading state information... Done
qbittorrent is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Any suggestions please?
Open a terminal and launch qbittorrent from it by typing "qbittorrent". Paste here the console output.
Couldn't set environment variable...
Peer ID: -qB2970-
HTTP user agent is qBittorrent v2.9.7
Peer ID: -qB2970-
You could try using PPA, it is much newer version qbittorrent 3.0.6 and libtorrent 0.16.4...
I'm not sure if this would solve the problem, but it would still be a good idea to upgrade from 2.9.7
[quote="sledgehammer_999"]
In terminal I enter “qbittorrent
” various times on the beginning just puts in the screen
l----@l--- -G41M-Combo:~$ qbittorrent
Peer ID: -qB2970-
my ADSL modem light keeps flashing for long time but nothing else stopping the terminal
another window come up with
Close this terminal?
There is still a process running in this terminal. Closing the terminal will kill it.
Peer ID: -qB2970-
since the newest user update for12.04, Qbit interface has disappeared....GRRR so annoying! What the hell did they forget? screw using the terminal I want it to work like it should!
