upnp not port forwarding
calabash
Post by calabash »
Hi
I am running qbittorrent  on Ubuntu 12.10 with a Technicolor TG587n v3 ADSL router.  upnp is set but does not open ports on my router.
I tried with some other clients including Transmission and Ktorrent with no problem, upnp ports are set with these clients.  Also tried Deluge and it also failed to set up the port forwarding.
As Deluge also uses libtorrent library I am assuming the issue is with libtorrent and not specifically with qbittorrent but I can't find any reports of a bug anywhere so hoping someone here can help.
libtorrent version is 0.16.4.0
So for now I've just manually set up port forwarding but would be nice to have this fixed.
