Problem with Removing Torrents
RockRock
Post by RockRock »
Hello
My qbittorrent automatically removes torrents (from the list inside the software) as soon as they are downloaded,
I don't want that to happen but I can't find a solution, Can you help me ?
Thanx in advance
unseen19
Re: Problem with Removing Torrents
Post by unseen19 »
Not the default behavior of course, did you changed anything?
Also are have you on the left side all sections checked with "ALL" to avoid any filtering? I'm referring here to the four sections named Status, categories, etc.
RockRock
Post by RockRock »
wow thanx, yes it was the filtering on the left which showed only the 'In Download' ones
still the problem is that every time I open the software it shows these 'In Download' ones,
is there a way to show 'all torrents' at the open ? can't find a way...
