[Help] Is there a way to redownload "missing file" files within the program?
So my situation is this, I downloaded lots of files in Qbit. Now in order to organize the files during the download popup I selected and created different subfolders. There were times where Qbit told me that the main folder I was putting everything in did not exist but paid not attention, which I regret! After completing all my downloads the main folder I put everything in was split into an exact copy of that folder. The first folder (folder A) had all the files and more sub category folders. Nothing wrong nor any errors occur when accessing the files or opening folders. The copy folder (folder B) had all the same files and sub folders inside it but when trying to open files or folders I kept getting nothing but errors in both windows explorer and subsequent programs that uses these files. I deleted folder B thinking it was some mistake not thinking that the 2 folders were somehow intertwined. Folder A was also deleted along side folder B and all of its contents. Right now I'm running recuva to restore these folders but I'm afraid that doing so will corrupt these files. I still have all the files listed in Qbit and my question is if there is a way to extract the torrent files to be able to download them again without having to manually get these torrents again or be able to somehow redownload from the program itself.
Re: [Help] Is there a way to redownload "missing file" files within the program?
Hi, similar problem.
I need to download again the same group of files because accidentally I haave destroyed some structure inside.
aBittorrent gives back a message like "The files are already in the list... have been merged" and nothing happens.
I looked for troubleshooting but no indications.
Then I found the list of downloaded files, in red characters, and just deleted the same name download, and the download interface appeared again.
Download was possible to activate.
