My version is 4.4.3.1 (32-bit)
When I reopen qBittorrent, I see all finished torrents are gone.
I want to seed. For a few days.
Finished downloads dissapearing from qBittorrent
Re: Finished downloads dissapearing from qBittorrent
This happened to me as well the last time I used qbittorrent portable years ago. Still searching for a stable and reliable one. Apparently, the installer version is the most reliable and portable ones are meh.SylverCheetah53 wrote: Mon Aug 01, 2022 10:04 am My version is 4.4.3.1 (32-bit)
I've been using qbittorrent 4.3.9 X64 in portable mode for like 9 months coming from ut 2.2.1.Blackhole wrote: Sat Aug 20, 2022 8:44 amThis happened to me as well the last time I used qbittorrent portable years ago. Still searching for a stable and reliable one. Apparently, the installer version is the most reliable and portable ones are meh.SylverCheetah53 wrote: Mon Aug 01, 2022 10:04 am My version is 4.4.3.1 (32-bit)
I haven't ever had torrents disappear. Computer is on 24/7 but have rebooted without issue.
I'm personally waiting for some more time before jumping to the 4.4.X branch.
Hope this helps
I don't have this problem, anymore. Since updating to 4.4.4, 64-bit version.
It's good. It's all good.
Did you create the portable by extracting the exe file like it is said in qbittorrent's Github wiki or did you download from 3rd party portable site?dawsonkm wrote: Mon Aug 29, 2022 6:00 pmI've been using qbittorrent 4.3.9 X64 in portable mode for like 9 months coming from ut 2.2.1.Blackhole wrote: Sat Aug 20, 2022 8:44 amThis happened to me as well the last time I used qbittorrent portable years ago. Still searching for a stable and reliable one. Apparently, the installer version is the most reliable and portable ones are meh.SylverCheetah53 wrote: Mon Aug 01, 2022 10:04 am My version is 4.4.3.1 (32-bit)
Hope this helps
Yeah just extracted the .exe file following the wiki instructions. I haven't had any problems and am happy with it.Blackhole wrote: Wed Aug 31, 2022 10:29 amDid you create the portable by extracting the exe file like it is said in qbittorrent's Github wiki or did you download from 3rd party portable site?dawsonkm wrote: Mon Aug 29, 2022 6:00 pmI've been using qbittorrent 4.3.9 X64 in portable mode for like 9 months coming from ut 2.2.1.Blackhole wrote: Sat Aug 20, 2022 8:44 am
Hope this helps
