my reshare is stuck at 99.8?
waltdisneypixar
Post by waltdisneypixar »
hi
i have reshared a file so i downloaded the torrent file and then i replaced the file i have in my pc file 100% the the file in the torrent folder file 0%
and then force recheck in qbittorent and stays at 99.8%
but i have the file 100% so i should be a seeder now with 100 but no
any help?
Re: my reshare is stuck at 99.8?
This often happens if Windows Defender, or any other security software removes the crack file, DLL file, or something from the torrent. And thus you don't have 100%. To counter this, you can de-select the file from qBittorrent so it will be simply ignored, or if you insist on sharing it, you can add the folder to Exceptions in your AV software.
waltdisneypixar
It is a mkv file
Hmm interesting. Anything in Execution Log?
It's only one file, no nfo, no sample?
waltdisneypixar
i dont know
look at the attachment i dont know why it says 99.8 the mkv file
i cant share because of that
and there is o seeds just me with the file
Screenshot 2022-08-03 114116.jpeg (240.43 KiB) Viewed 2228 times
unseen19
Post by unseen19 »
The content of the torrent is not the same, the jpg/nfo are different or not the same.
Either the source/destination torrent have not the same content (not trying a cross seed?) or if you make the .torrent yourself you selected the file instead of the whole folder
What if you untick the .exe and other files in the folder? Just for science..
waltdisneypixar
same. i had already tried that
