QBittorent
Hawaii33
QBittorent
Post by Hawaii33 »
Got notification of new version, downloaded and tried to install. Went well until last part, received notice that QBit was running and to close it. Could not find it running, went to Task Mgr. and closed it there. Tried to install, same message. Rebooted and made sure program was not running, tried install, same message that it was running. Cannot see anywhere that the program is running but the install program seems to think that it is. Should I delete the old program and try again ? Really don't know what to do at this point.
Thanks for any help.
TimK
Re: QBittorent
In Task Manager -> Details (tab on top).. there should be a qbittorrent.exe
Close that.
Could you check?
