1. I like to add torrents while out of my home. The paid android app doesn't seem to connect and allow me to add torrents, it's only when I return to my home network via WiFi that it works
2. I would like completed downloads to be moved to a folder called "finished" I have selected this folder via settings, but it doesn't seem to move them.
1/ I'm not aware of any paid QBT app (but might exists). The app should be able to connect from outside with a port forwarding on your router, but this is weak and dangerous regarding the security. A VPN or reverse proxy may be the best choice.
2/ there are some topics about this on the last version, e.g. https://github.com/qbittorrent/qBittorrent/issues/17782
For the time being do not move torrent after completion and set the default location as the final folder may be a workaround.Depending the setup it may not be optimal but in fact...I never moved the torrents once complete .
