Option to remove (New Version Available) Window!
Ceroqin
Post by Ceroqin »
I have read some questionable reasoning as to why there is no option that allows qBittorent to automatically update.
So my suggestion is, that there should at the very least, a option to turn off the "New version available" popup, it's quite annoying having to close 2 windows every single time it gets freshly opened up.
That should be a fair solution even for the anti automatic update people.
Re: Option to remove (New Version Available) Window!
It's in Settings.
"Check for program updates."
Ceroqin
Post by Ceroqin »
Peter wrote: Sun Oct 16, 2022 12:03 pm It's in Settings.
Thank you.
