Difference between libtorrent 1.2.x and libtorrent 2.0.x
finchcz
Post by finchcz »
Hello there,
please, can someone answer the following questions?
- What is the difference between libtorrent versions mentioned in subject, pros/cons? (I'm currently on win10 qB 4.4.2 with libt 2.0.5.0)
- If I will want to use qB with different version of libtorrent, is it just safe to reinstall/update application with the other version of libtorrent?
Thank you.
Gretas
Re: Difference between libtorrent 1.2.x and libtorrent 2.0.x
Post by Gretas »
Same question. But, as I can see, developers not wish answer to popular questions. Sad. But I will to pay lilcense for this program, but payment should guarantee quality support.
Fuga
Post by Fuga »
Since payment is not required support is not guaranteed.
I mean, end-user wise, I doubt you'll notice much.
For what v2 does/offers, check this: https://www.libtorrent.org/upgrade_to_2.0-ref.html
