Hi everyone,
I have moved my torrents from a Windows qbit 4.5 install to a Linux (Unraid/Docker) 4.5 install, and am having problems getting the torrents back up.
The torrent files themselves have been moved, as well as the .torrent and fastresume files under BT_backup. I also moved the qBittorrent-data.ini content to qBittorrent-data.conf to maintain my global statistics (which works).
In the new qbit client, I can see all my torrents, under proper categories and save location, but they all show as 0% done, status paused (the added on date and uploaded seem to show the correct info from the what it was in the Windows qbit). If I try to force recheck the torrents, nothing happens. If I force resume one, it just re-downloads the whole thing.
I have checked and even from within the docker container under a terminal, I can see the torrent files and they appear to be correct, and have the correct permissions. I even checked on one torrent that I had done a re-download, and the file is identical (same location, same name, same size, same permissions), so as best as I can tell, the physical files themselves are not at issue.
However I did notice that in that example, the fastresume file was fairly different.
Has anyone made this transition before or can offer any assistance? Thanks!
Moving torrents from Windows 4.5 to Linux 4.5
Re: Moving torrents from Windows 4.5 to Linux 4.5
A new torrent on the new setup works? To avoid permission issue, or anything related.
When a force-recheck does not start it's most of time due to file not found/no access.
The last time I did such I didn't move configuration files between platforms but used the autoadd feature. Of course if you still have the .torrent file.
I dropped all of them in the configured autoadd folder, they were added to QBT interface and did some location change to make it right. It can be a lot of work (it was for me), but worked
