What settings do I copy to keep my settings?
sensualfreespirit
Post by sensualfreespirit »
I just redid my computer & copied the settings & nothing copied over when I reinstalled QB & copied that file over. :(
What do I copy if that doesn't work?
qBittorrent in Local folders.
Re: What settings do I copy to keep my settings?
There are 2 folders.
I'll just copy Priit's post:
viewtopic.php?p=39745#p39745
sensualfreespirit
Thanks, but I don't have anything in %APPDATA%\qBittorrent
That's not where settings usually are b/c there's only these 3 folders.
https://imgur.com/XoYxGIy
Uhm, you had that folder on the old PC, and that's what you copy over.
%APPDATA% is just a Windows "trick", it's: C:\Users\YOUR_USER_NAME\AppData\qBittorrent
%LOCALAPPDATA% is: C:\Users\YOUR_USER_NAME\Local\qBittorrent
And you basically need both folders.
