Sir, if you may,..
thankyou so much, for making such a wonderful and brilliant torrent app without any advertisement...
but if you may,... this is just a suggestions.. you could also add menu for search item in RSS, and also delete button for deleting oll torrent rss that has been downloaded..
the use case in search bar would be like these:
1. if I click one of our RSS address on our left (rss feed) for example tab TV Series,
2. when we click it, the search option will only search on that tab only (TV Series) address.
3. but if we click unread.. the search method would searching the entire tab or addresses..
4. if you may, you can also make the item of the tab, with sorting method, like by size, or by date..
and the use case for deleting old torrent are:
1. it will be deleting clicked item and old item in the tab address.. one by one or together at the same time..
I'm sorry for my bad English, I hope you could understand, and these are just suggestions, to make your app better..
Thankyou Sir..
search and delete old RSS menu
- SnapCrab_qBittorrent v450_2022-12-9_10-55-44_No-00.png (983 KiB) Viewed 22130 times
Re: search and delete old RSS menu
This would be an interesting addition.
- Newbie
Thanks for that interesting addition
