qBittorrent-nox + VPS + TeamDrive
AcbEzio
Post by AcbEzio »
Recently I have purchased a fedora VPS and configured rclone and qBittorrent-nox without an issue.
I mounted a teamdrive using below commands.
$ mkdir ~/gdrive
$ rclone mount td1: ~/gdrive/
After the mounting I gave qbittorrent save path as "/home/fedora/gdrive" in web ui. When I added a new torrent qbittorrent "Stautus" show ERRORED.
I need to download torrent files to directly to TeamDrive without compromising VPS storage.
Is there any solution for this issue?
Re: qBittorrent-nox + VPS + TeamDrive
Damn this TeamDrive looks EXPENSIVE omg.
Anyway, try to copy files to and from this mount you just did. As your user. See if that works.
(Here is some documentation that lists arguments you could try: https://rclone.org/commands/rclone_mount/)
