Malwarebytes blocks outbound website call
Terrax
Post by Terrax »
Hello, so I'm receiving close to a hundred (100) of the messages attached in the screenshot.
qbittorrent malwarebytes.png (22.92 KiB) Viewed 3401 times
The IP and port number are different. Could someone please explain is this behavior expected and what website is qbittorrent trying to reach?
Zoloft
Re: Malwarebytes blocks outbound website call
Post by Zoloft »
Someone, who's ip address is flagged as malware by malwarebytes is trying to connect to you to get a torrent you are seeding.
Jendrej
Post by Jendrej »
I installed MB recently to try it out and got those too. It's just blocking IPs of peers that have been blacklisted (probably for something else than torrenting - a lot of people use shared VPNs or shared servers).
I just disabled the web protection feature. Even for normal browsing, I find it those more annoying than useful. They block "suspicious things" that may or may not be malware - basically all false positives
TPISNOTWHOIAM
Post by TPISNOTWHOIAM »
I have the same issue though I am not seeding nor have any files downloaded. I constantly get the alerts for awhile even though I have exited qBittorrent and there are no instances of it running according to Task Manager.
TPISNOTWHOIAM wrote: Wed Dec 18, 2024 4:52 am I have the same issue though I am not seeding nor have any files downloaded. I constantly get the alerts for awhile even though I have exited qBittorrent and there are no instances of it running according to Task Manager.
It could be also just alerting to a tracker, DHT, etc. These anti-virus products are 99% snakeoil, scare tactics and straight up scam in 2024. They had to change their legit business model into shady after Microsoft introduced a perfectly working antivirus with Defender.
