Hotio's legacy 4.3.9 docker container is causing high CPU usage even with just seeding around 600+ torrents
kevindd992002
Post by kevindd992002 »
As the title says, I started using qbittorrent and I was suggested to stay with 4.3.9 as it is currently the most stable version. However, just by running the container in my Synology DS1817+ it's already taking around 40% CPU usage (based on htop). This is simply seeding 600+ torrents. When I download stuff, it pegs the CPU to between 90-100%. I don't know what's wrong with this. This container shouldn't be taking that much CPU resource.
Here's my config:
[AutoRun]
enabled=true
program="curl -XPOST http://cross-seed:2468/api/webhook --data-urlencode \"name=%N\""
[BitTorrent]
Session\BTProtocol=TCP
Session\Categories=@Variant(\0\0\0\b\0\0\0\x14\0\0\0\"\0t\0v\0-\0u\0h\0\x64\0.\0\x63\0r\0o\0s\0s\0-\0s\0\x65\0\x65\0\x64\0\0\0\n\0\0\0\f\0t\0v\0-\0u\0h\0\x64\0\0\0\f\0t\0v\0-\0u\0h\0\x64\0\0\0\n\0\0\0\f\0t\0v\0-\0u\0h\0\x64\0\0\0 \0t\0v\0-\0h\0\x64\0.\0\x63\0r\0o\0s\0s\0-\0s\0\x65\0\x65\0\x64\0\0\0\n\0\0\0\n\0t\0v\0-\0h\0\x64\0\0\0\n\0t\0v\0-\0h\0\x64\0\0\0\n\0\0\0\n\0t\0v\0-\0h\0\x64\0\0\0&\0t\0v\0-\0\x61\0n\0i\0m\0\x65\0.\0\x63\0r\0o\0s\0s\0-\0s\0\x65\0\x65\0\x64\0\0\0\n\0\0\0\x10\0t\0v\0-\0\x61\0n\0i\0m\0\x65\0\0\0\x10\0t\0v\0-\0\x61\0n\0i\0m\0\x65\0\0\0\n\0\0\0\x10\0t\0v\0-\0\x61\0n\0i\0m\0\x65\0\0\0\x14\0s\0o\0n\0\x61\0r\0r\0-\0u\0h\0\x64\0\0\0\n\0\0\0\x14\0s\0o\0n\0\x61\0r\0r\0-\0u\0h\0\x64\0\0\0(\0s\0o\0n\0\x61\0r\0r\0-\0h\0\x64\0.\0\x63\0r\0o\0s\0s\0-\0s\0\x65\0\x65\0\x64\0\0\0\n\0\0\0\x12\0s\0o\0n\0\x61\0r\0r\0-\0h\0\x64\0\0\0\x12\0s\0o\0n\0\x61\0r\0r\0-\0h\0\x64\0\0\0\n\0\0\0\x12\0s\0o\0n\0\x61\0r\0r\0-\0h\0\x64\0\0\0\x18\0s\0o\0n\0\x61\0r\0r\0-\0\x61\0n\0i\0m\0\x65\0\0\0\n\0\0\0\x18\0s\0o\0n\0\x61\0r\0r\0-\0\x61\0n\0i\0m\0\x65\0\0\0*\0r\0\x61\0\x64\0\x61\0r\0r\0-\0u\0h\0\x64\0.\0\x63\0r\0o\0s\0s\0-\0s\0\x65\0\x65\0\x64\0\0\0\n\0\0\0\x14\0r\0\x61\0\x64\0\x61\0r\0r\0-\0u\0h\0\x64\0\0\0\x14\0r\0\x61\0\x64\0\x61\0r\0r\0-\0u\0h\0\x64\0\0\0\n\0\0\0\x14\0r\0\x61\0\x64\0\x61\0r\0r\0-\0u\0h\0\x64\0\0\0(\0r\0\x61\0\x64\0\x61\0r\0r\0-\0h\0\x64\0.\0\x63\0r\0o\0s\0s\0-\0s\0\x65\0\x65\0\x64\0\0\0\n\0\0\0\x12\0r\0\x61\0\x64\0\x61\0r\0r\0-\0h\0\x64\0\0\0\x12\0r\0\x61\0\x64\0\x61\0r\0r\0-\0h\0\x64\0\0\0\n\0\0\0\x12\0r\0\x61\0\x64\0\x61\0r\0r\0-\0h\0\x64\0\0\0*\0m\0o\0v\0i\0\x65\0s\0-\0u\0h\0\x64\0.\0\x63\0r\0o\0s\0s\0-\0s\0\x65\0\x65\0\x64\0\0\0\n\0\0\0\x14\0m\0o\0v\0i\0\x65\0s\0-\0u\0h\0\x64\0\0\0\x14\0m\0o\0v\0i\0\x65\0s\0-\0u\0h\0\x64\0\0\0\n\0\0\0\x14\0m\0o\0v\0i\0\x65\0s\0-\0u\0h\0\x64\0\0\0(\0m\0o\0v\0i\0\x65\0s\0-\0h\0\x64\0.\0\x63\0r\0o\0s\0s\0-\0s\0\x65\0\x65\0\x64\0\0\0\n\0\0\0\x12\0m\0o\0v\0i\0\x65\0s\0-\0h\0\x64\0\0\0\x12\0m\0o\0v\0i\0\x65\0s\0-\0h\0\x64\0\0\0\n\0\0\0\x12\0m\0o\0v\0i\0\x65\0s\0-\0h\0\x64\0\0\0\"\0m\0\x61\0n\0u\0\x61\0l\0.\0\x63\0r\0o\0s\0s\0-\0s\0\x65\0\x65\0\x64\0\0\0\n\0\0\0\f\0m\0\x61\0n\0u\0\x61\0l\0\0\0\f\0m\0\x61\0n\0u\0\x61\0l\0\0\0\n\0\0\0\f\0m\0\x61\0n\0u\0\x61\0l)
Session\DisableAutoTMMByDefault=false
Session\DisableAutoTMMTriggers\CategorySavePathChanged=false
Session\DisableAutoTMMTriggers\DefaultSavePathChanged=false
Session\Tags=TorrentLeech, issue, IPTorrents, HDTorrents, Nyaa, cross-seed, noHL, FileList, TorrentDay
[Core]
AutoDeleteAddedTorrentFile=IfAdded
[Preferences]
Advanced\RecheckOnCompletion=false
Advanced\trackerPort=9000
Bittorrent\MaxConnecs=200
Bittorrent\MaxUploads=150
Bittorrent\MaxUploadsPerTorrent=30
Connection\GlobalDLLimit=72000
Connection\GlobalUPLimit=64000
Connection\PortRangeMin=62959
Connection\ResolvePeerCountries=true
Connection\UPnP=false
Downloads\SavePath=/data/torrents/
Downloads\TempPath=/data/torrents/intermediate/
Downloads\TempPathEnabled=false
DynDNS\DomainName=changeme.dyndns.org
DynDNS\Enabled=false
DynDNS\Password=
DynDNS\Service=0
DynDNS\Username=
General\Locale=en
MailNotification\email=
MailNotification\enabled=false
MailNotification\password="Dreamcast12345,"
MailNotification\req_auth=true
MailNotification\req_ssl=false
MailNotification\[email protected]
MailNotification\smtp_server=smtp.changeme.com
MailNotification\username=kevindd992002
Queueing\IgnoreSlowTorrents=true
Queueing\MaxActiveDownloads=-1
Queueing\MaxActiveTorrents=-1
Queueing\MaxActiveUploads=-1
Queueing\QueueingEnabled=true
WebUI\Address=*
WebUI\AlternativeUIEnabled=false
WebUI\AuthSubnetWhitelist=192.168.10.0/24, 192.168.20.0/24, 172.19.0.0/16
WebUI\AuthSubnetWhitelistEnabled=true
WebUI\BanDuration=3600
WebUI\CSRFProtection=true
WebUI\ClickjackingProtection=true
WebUI\CustomHTTPHeaders=
WebUI\CustomHTTPHeadersEnabled=false
WebUI\HTTPS\CertificatePath=
WebUI\HTTPS\Enabled=false
WebUI\HTTPS\KeyPath=
WebUI\HostHeaderValidation=false
WebUI\LocalHostAuth=false
WebUI\MaxAuthenticationFailCount=5
WebUI\Password_PBKDF2={redacted}
WebUI\Port=8080
WebUI\RootFolder=/app/vuetorrent
WebUI\SecureCookie=true
WebUI\ServerDomains=*
WebUI\SessionTimeout=3600
WebUI\UseUPnP=false
WebUI\Username={redacted}
[RSS]
AutoDownloader\DownloadRepacks=true
AutoDownloader\SmartEpisodeFilter=s(\\d+)e(\\d+), (\\d+)x(\\d+), "(\\d{4}[.\\-]\\d{1,2}[.\\-]\\d{1,2})", "(\\d{1,2}[.\\-]\\d{1,2}[.\\-]\\d{4})"
Any help would be very much appreciated. Thanks in advance!
Re: Hotio's legacy 4.3.9 docker container is causing high CPU usage even with just seeding around 600+ torrents
I mean this should be reported to the person who develops/maintains this docker image. It's not official, it does not belong to the qBittorrent team. In fact, there is no official image at all.
I am not trying to say "don't post here at all", but basically we can only help with issues regarding Docker setups. Like how do you run docker, how do you migrate from/to docker, that sort of stuff. But if an issue comes up like this one, you have to report it to the person/team who maintains the image because only they can fix it.
