I have a qBittorrent 4.5.2 installation running on macOS (13.2.1).
I would like to port this across to a Linux Debian VM. (I assume the recommendation would be to also use qBittorrent 4.5.2).
Does anybody know the best/recommended way to port the configuration, as well as completed/incomplete torrent state across?
(If there's a seamless way to lift/shift, that would be amazing).
Are there any caveats, or gotchas I should be aware of?
Thanks!
Victor
