lost of torrents
pierre
lost of torrents
Post by pierre »
Hi, had my PC crash, unable to repair, so i got my harddrive to a store to recuperated my qbt download folder and many other things.
download the folder on an other pc and install qbt, when on the setting to find the folder path
now on the status none appear except de 3 new ones that i have dl.
possible to get them on seed again?
tks to help
unseen19
Re: lost of torrents
Post by unseen19 »
QBT is based on profile so if you retrieve your old profile and copy it you may be able to retrieve the loaded .torrents (this will exclude newer ones)
https://github.com/qbittorrent/qBittorr ... -Questions
Considering the profile will be loaded with torrent path kept, be sure to have the media file on the right destination to avoid a massive download.
I put QBT in paused mode most of the time for such, with a "force recheck" to confirm the link between loaded .torrent and media files.
ALTERNATIVE>> go on the tracker and download only the .torrent of each media file. Do a "force recheck" and go on.
pierre
Post by pierre »
Tks, everything is back!!! :D
