qBittorrent stopped showing torrent completion notifications
BigBrotherrr
Post by BigBrotherrr »
Hi! qBittorrent suddenly stopped showing notifications when a torrent is competed. I didn't change anything, I have this option enabled, it worked just fine until recently. My version is 4.4.5 (64 bit), Windows 10 21H2.
Re: qBittorrent stopped showing torrent completion notifications
Which version of Windows are you using? Windows can mute notifications, and you can also mute them yourself. It's kind of like a smartphone OS in that regard (Win 10, Win 11). Check if that happened.
In qBittorrent, the option is in Advanced -> Display Notifications.
