Windows XP version?
dfarns321
Windows XP version?
Post by dfarns321 »
Is there a version of qbittorrent that works with Windows XP.
(I tried to find this information using the forum search engine but it ignores any search request with terms having fewer than 3 letters,)
Re: Windows XP version?
Very old versions, around 3.3 or 3.4?
I'd recommend using uTorrent 1.6.1 instead, I think that one works on XP. Just don't use WebUI with any client, that'd be straight-up suicide.
dfarns321
Post by dfarns321 »
I'm already using uTorrent 1.8.5 and that works with WinXP. But recently almost all the UDP trackers have been showing "invalid URL" and don't work at all. That leaves DHT, LPD, and PEX working and for the English football games I'm looking for it's slim picking.
So I wanted to try qBittorrent and see if this Invalid URL problem would go away. I'll look for the older versions you mentioned and try them out if I can find them.
What is it about WebUI that is so bad?
