I have many feeds to enter into a new qBittorrent v4.3.9 install. The RSS Rules can be easily imported as a json but I haven't found a way to import the RSS Feeds.
Rather than laboriously enter one at a time via the GUI, is there a way to add them with an editor modifying a file in Ubuntu 20.04?
How to enter multiple RSS feeds?
Re: How to enter multiple RSS feeds?
Go into "%APPDATA%\rss" (or find the same folder in your distro) and feeds.json file.
From what I gather, each entry has a UID, but the code will generate a UID if its missing from the file. (rss_session.cpp)
(Uuid is generated through Qt's QUuid class - https://doc.qt.io/qt-6/quuid.html#createUuid)
So you could simply just fill up the feeds.json with Python (Python also has Qt bindings.)
Thankyou so much!
Found feeds.json in HOME/.config/qBittorrent
This will save me hours
- Newbie
To maximize the utility of your bundles, combine pertinent sources. Now ymini crosswordou can filter your bundle to obtain the most tailored feed. Copy the JS or iFrame code fragment and paste it into your HTML website or blog in order to incorporate your compilation.
To enter multiple RSS feeds in qBittorrent on Ubuntu 20.04:
1. Locate the `rss.xml` file in `~/.config/qBittorrent`.
2. Edit the file, adding your RSS feed entries manually.
3. Save the file.
4. Restart qBittorrent to apply the changes.
Digital-trebuchet.com
3. Save the file.
@clentjohn
I can't find an rss.xml file in ~/.config/qBittorrent
~/.config/qBittorrent$ ls
qBittorrent.conf qBittorrent-data.conf rss watched_folders.json
~/.config/qBittorrent$ cd rss
~/.config/qBittorrent/rss$ ls
download_rules.json feeds.json storage.lock
