Ubuntu 22.04.1 - Wayland - Flatpak 1.12.7 - qBittorrent/4.5.2
neuron
Post by neuron »
Ubuntu 22.04.1
Wayland
Flatpak 1.12.7
qBittorrent/4.5.2
flatpak -v run org.qbittorrent.qBittorrent
F: No installations directory in /etc/flatpak/installations.d. Skipping
F: Opening system flatpak installation at path /var/lib/flatpak
F: Opening user flatpak installation at path /home/xxxxxx/.local/share/flatpak
F: Skipping parental controls check for app/org.qbittorrent.qBittorrent/x86_64/stable since parental controls are disabled globally
F: /var/lib/flatpak/runtime/org.kde.Platform/x86_64/5.15-/files/lib32 does not exist
F: Allocated instance id 108
F: Add defaults in dir /org/qbittorrent/qBittorrent/
F: Add locks in dir /org/qbittorrent/qBittorrent/
F: Allowing dri access
F: Allowing host-fs access
F: skipping export for path /usr/libx32
F: Allowing wayland access
F: Running 'bwrap --args 40 xdg-dbus-proxy --args=42'
F: Running 'bwrap --args 40 qbittorrent'
QSocketNotifier: Can only be used with threads started with QThread
TransferListWidget(0x5603e9aa24f0) does not have a property named "downloadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "forcedDownloadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "downloadingMetadataStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "allocatingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "stalledDownloadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "stalledUploadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "uploadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "forcedUploadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "pausedDownloadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "pausedUploadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "errorStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "missingFilesStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "queuedDownloadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "queuedUploadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "checkingDownloadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "checkingUploadingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "checkingResumeDataStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "movingStateForeground"
TransferListWidget(0x5603e9aa24f0) does not have a property named "unknownStateForeground"
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
OpenType support missing for "Ubuntu", script 11
Its ok or we can install something?
Re: Ubuntu 22.04.1 - Wayland - Flatpak 1.12.7 - qBittorrent/4.5.2
I mean, I think you can use the PPA version, if you'd like to use the latest qBittorrent on 22.04.
(For fixing Flatpak, I have no clue, I had a very bad experience with both Flatpak and Snap on Linux, varying from terrible to just bad. The idea is awesome, but other than Certbot, I never had a software work OK with it.)
neuron
Post by neuron »
Peter wrote: Wed Apr 26, 2023 5:31 pm I mean, I think you can use the PPA version, if you'd like to use the latest qBittorrent on 22.04.
Thank you Peter,
I'm testing and using SandBoxs and Containers :D
Firefox for ex.
PPA ? I can compile qBit. in many OS - MacOS, Linux ...
Im using 4.5.2 in Flapak
Firefox and other APP work in Snap, the problem is slow and I don't know what is doing in my Syst. >:D
And use /etc/apparmor with Firefox, Snap, Libreoffice, Cupsd ...
The error:
"TransferListWidget(0x5603e9aa24f0) does not have a property named ..."
is in the last section - TransferListWidget
"Following way of changing TransferList row's color is removed after version 4.2.5, please change your bundle files accordingly and instead use config.json"
https://github.com/qbittorrent/qBittorr ... Bittorrent
The creator /maint. of this build is in this Forum?
Best Regrds,
Neuron
neuron
Post by neuron »
neuron wrote: Wed Apr 26, 2023 10:36 pm
The error:
This errors disappear with:
stylesheet.qss (empty or ...) and config.json
Only this:
_____________________________________________________________
But colors don't change ... I don't have a Theme load.
In this version ( Flatpak ) I have several files in ~/.var/ .....:
stylesheet.qss, config.json, feeds.json, categories.json, qBittorrent .conf
Best Regrds,
Neuron
