My experience:
If you have multiple torrents downloads, the total time taken for all downloads, will be less if you download one at a time.
It would be nice to be able to have a sequence / one-at-a-time order to torrents / files to be downloaded.
Bonus points if after completion of a download, the app automatically deletes the torrent.
Thanks!
order the torrents one-at-a-time
Re: order the torrents one-at-a-time
Hi.
Go into settings, BitTorrent, and enable Queueing.
You can do like "1" for active downloads, and you can input "-1" in the other two and this way you can seed 1000, but, you will only download 1 at once.
You can also adjust the "Do not count these" just below, so slow downloads that don't bother anyone will be ignored by the queue.
Good luck!
Good luck!
- Newbie
