File priority
donnje
File priority
Post by donnje »
Is it possible to give a download priority to one file over another?
thanks
rdalek
Re: File priority
Post by rdalek »
Pretty sure this will work. First, select the torrent in the list. Then click the Content tab at the bottom. Place the mouse pointer over the file you want to change and right click. In the menu, move mouse pointer to Priority and then select the priority level you want.
See if that helps.
