I have qbittorrent on a remote machine. As my local machine is 4K and ti's a laptop I need to use the window's built in scale function (250% currently).
As the RDP session is too small I re-scale in there to 250% as well.
The result for any other application is acceptable and everything feels like local in size.
The only issue I have found so far is in the text of the settings of qBittorrent only (settings menu looks ok though).
Settings text too small (via RDP with windows scaling on)
Re: Settings text too small (via RDP with windows scaling on)
Install the Qt6 version from the download page.
That worked. Thank you!
