Peering with two connections
GoodDayToDie
Post by GoodDayToDie »
I explain the problem. I am connected to Wi-Fi, which is slow, and I also can connect a 4G-smartphone via USB with the Internet sharing function.
Neither one nor the other speed individually does not suit me. The sum of the speeds will suit me. Is it possible to peering files by summing the speeds of two connections?
Sorry if the question is stupid. Thank you.
qBittorrent v.4.5.4 (64-bit)
Windows 10 Pro 22H2 (64-bit)
Re: Peering with two connections
https://speedify.com/
^ This is exactly what you want. ^
I read that you can set up a virtual-switch in Windows yourself to achieve the same thing for free, but someone tried and it didn't work. You could always try though. "Combine two internet speeds Windows 10" for example.
(edit: put the wrong link first, same company though)
