An example of the Column Header Text ...
Name | Total Size | Size | Progress | Status | Seeds | Peers | Down Speed | Up Speed | ETA ...
Problem ...
If the width of the columns are made narrow the column header text is cut off (the data below is still visible)
Suggestion 1.
Make the column header text as verbose (short) as possible.
eg
"Total" not "Total Size"
"Up" or "
"Down" or "
Suggestion 2.
External Language file that allows the user to edit the text used in the column header text.
