Avoid using IPV6 ULA for outgoing connections
Pentium4User
Post by Pentium4User »
Hello!
I have 2 GUA IPv6 addresses and one ULA (fd00:xxx) on my interface.
qBittorrent sometimes select the ULA address for outgoing connections which won't work because the reply from the peer will never ever reach my system.
When connecting to IPv6 GUA, always a GUA address of the system can be used.
A temporary workaround is to explicitly set the IPv6 address in the advanced settings.
Is that a problem in QBittorrent, libtorrent or on my Debian system itself?
/etc/gai.conf doesn't have any settings enabled.
Kind regards
Pentium4User
Re: Avoid using IPV6 ULA for outgoing connections
Phew.
You should report this, here: https://github.com/qbittorrent/qBittorrent/issues
Thanks, the team will get back to you.
(I found that isSiteLocal(), but I bet they know something 100 times better.)
Pentium4User
Peter wrote: Tue Sep 19, 2023 9:59 am Thanks, the team will get back to you.
Site-local is the same scope, but another address range (fec0::/10).
