I'm in the same boat. When I go to qbittorrent: view: search I get a popup that the Python libraries are missing and it proceeds to install python 3.10.11. But whatever PATH statement (user/system) I add, qB keeps insisting the libraries are missing.
I just did a fresh installation (removed all settings and torrents) and went to the latest RC2 (v4.6.0). Before that I was on the latest 4.5.? stable branch.
What else is there left for me to try? I removed all Python versions with iobit, had qB install its version and still it complains. I also downloaded the latest Python version and installed that one. Still, qB insists Python is not to be found on my system
Also see: https://stackoverflow.com/questions/508 ... 0#52913040
Running Win 11 for what it's worth... Disabling Avast made no difference (nor should it have)
Please advise?
Devnullius
C:\Windows\System32>py
Python 3.12.0 (tags/v3.12.0:0fb18b0, Oct 2 2023, 13:03:39) [MSC v.1935 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
