What is the difference between lt20 qt6 and the none lt20 qt6 version?
Archivist
Post by Archivist »
Does it matter which version to install of 4.6.0?
Is one "better" than the other?
Re: What is the difference between lt20 qt6 and the none lt20 qt6 version?
They both use Qt6.
The "none lt20" uses the old libtorrent.
The lt20 should work fine, but some people still have trouble with it so the project provides both versions so users can swap between them with ease.
